1986 Cadillac Fleetwood won'pass emissions
142,295 MILES • V8 • 2WD • AUTOMATIC
STEVEB321
have a 86 fleetwood with a 305 olds motor that has failed emission test with high HC 5.19 and OC 173.85 had complete tuneup,carb rebuilt,new O2 sensor car runs good any ideas?
Sep 22, 2008 at 1:54 PM
  • 75,988 POSTS
You sure the readings are not reversed and should read like this CO 5.9 HC 173.85
Sep 22, 2008 at 3:43 PM
STEVEB321
yes you are correct numbers are reveresed any ideas on how to get this to pass?
Sep 22, 2008 at 9:30 PM
  • 75,988 POSTS
Start with the scrubber-called catalytic converter and second it with the snitcher the oxygen sensor
Sep 22, 2008 at 9:40 PM
STEVEB321
put new O2 so you think cat converter will correct this issue?
Sep 22, 2008 at 10:32 PM
  • 75,988 POSTS
CO is too high-inspect and test the coolant temperature sensor could be stuck in the open loop mode dumping fuel at it-
Do you have the O2/CO2/NOx readings?
Sep 22, 2008 at 10:45 PM
STEVEB321
put in new temp sensor emission results are
HC 5.19 should be 1.60 or less CO 173.85 should be 15.00 or less and NOX .082
Sep 23, 2008 at 2:25 AM
  • 75,988 POSTS
Have the catalytic converter check with a gas analyzer before and after the catalytic converter this wil tell you if its doing its job
Sep 23, 2008 at 5:14 AM
