1985 Cadillac Fleetwood WIG-WAG HEADLIGHTS ON A FLEETWOOD C
1985 CADILLAC FLEETWOOD
89,000 MILES • V8 • FWD • AUTOMATIC
NO1BLACKDRAGON
Hello,I'm A Vol.Firefighter And I Own A 85 Fleet wood Caddy I Have Been Able To Strobe Out All My Lights But The Head Lights And Want To Know If There Is A Cheep Easy Way To Wig Wag My High Beams Does Anyone Know If This Is Possable On This Make And Model And If So Can It Be Done With Out Damage To The Head Lights And Or Wiring?? HELP!
Feb 22, 2010 at 2:08 PM
MIKE H R
  • 3,094 POSTS
You can change the headlight so they alternate on and off. Using a alternate flasher you can tie into the headlights. The problem with it is that you have to put in three switches so when the healights are used there is no feed back of voltage into the electrical system and flasher . I had put the system in one of my own cars some time ago. The best thing to get is a module that takes care of it. The system costs about $54.95 and is available through
swps.com public safety equipment. It comes with all the instructions and is controlled by one switch.
Feb 25, 2010 at 2:33 AM
