1985 Cadillac Fleetwood Radiator Fan Relay
SINGS10R
Engine Cooling problem
1985 Cadillac Fleetwood V8 Front Wheel Drive Automatic
Radiator Fan Relay, where is it located and is there only 1 for both fans or 1 for each fan?
Apr 11, 2010 at 12:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
should just have one cooling fan relay on the right side of firewall in the engine compartment
Apr 11, 2010 at 2:26 PM
SINGS10R
I tested the fan motors by turning on the Ac after the engine ran a few minutes. Both fans came on. Would the relay still be a problem? Also, I see no relay on the firewall but I have 2 side-by-side closer to the front of the car on the driver's side.
Apr 12, 2010 at 1:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if fan comes on then relay is good. check engine coolant temp. sensor if fan does not come on at proper temperature.
Apr 12, 2010 at 3:16 AM
