2007 Cadillac Escalade Ext
DAPAGANI
2007 Cadillac Escalade Ext 50000 miles
i have changed brake pads in many gm vehichles, never on cadillac, my question is do i need any special tools to change front pads or will my metric hex tools work to remove the caliper mounting bolts?
Jan 12, 2010 at 3:41 AM
FACTORYJACK
  • 4,159 POSTS
If you are just changing the pads, you just need to remove one of the caliper bolts, and it will rotate up. I think they are 15mm. If your referring to hex as allen, they are just a standard socket.
Jan 12, 2010 at 3:33 PM
