2004 Cadillac Escalade Ext Whining while driving fast
70,000 MILES • V8 • AWD • AUTOMATIC
PAULY.G
My battery recently died. after jump starting the truck the tachometer stopped working properly and the truck rides like the front wheels are engaged in four wheel drive and there is a whining from the fron. They both started at the same time which makes me believe i roasted something, but what. I checked all fuses and found nothing blown. Is there something i could check/test or do i have to go back to the dealer? Please help!
Thanks!
Pauly.g
Jan 27, 2010 at 11:48 AM
FACTORYJACK
  • 4,159 POSTS
There are cluster issues on 04 C/K trucks, if you are at 70k I believe you are at the threshold for getting it covered under a special policy for warranty. Here is the bulletin:
#07187C: Special Coverage Adjustment - Instrument Panel Cluster Gauge Needle Function - (Mar 20, 2009)
Subject: 07187C -- SPECIAL COVERAGE ADJUSTMENT - INSTRUMENT PANEL CLUSTER GAUGE NEEDLE FUNCTION
Models: 2003-2004 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT
2005 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT (U.S. ONLY)
2003-2004 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE
2005 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE (U.S.ONLY)
2003-2004 GMC SIERRA, YUKON, YUKON XL
2005 GMC SIERRA, YUKON, YUKON XL (U.S. ONLY)
THIS BULLETIN IS BEING REVISED TO INCLUDE CERTAIN 2005 MODEL YEAR VEHICLES IN THE U.S. ADDITIONALLY, FOR U.S. 2003-2005 MODEL YEAR VEHICLES, GM WILL PROVIDE THE INSTRUMENT PANEL CLUSTER (IPC) ONLY, AT NO CHARGE TO THE CUSTOMER FOR VERIFIED FAILURES BETWEEN 70,001 MILES (110,001 KM) AND 80,000 MILES (130,000 KM). ANY ADDITIONAL COSTS, INCLUDING LABOR TO REPLACE THE INSTRUMENT PANEL CLUSTER, WILL BE THE RESPONSIBILITY OF THE CUSTOMER. DEALERS WILL BE RESPONSIBLE FOR THE RETURN OF THE CUSTOMER'S IPC BACK TO THE ELECTRONIC SERVICE CENTER. PLEASE DISCARD ALL COPIES OF BULLETIN 07187B, ISSUED SEPTEMBER 2008..
CUSTOMERS ARE BEING INSTRUCTED TO CONTACT THE DEALERSHIP TO ARRANGE AN APPOINTMENT IF THEY BELIEVE THEIR VEHICLE HAS THIS CONDITION. THE CUSTOMER IS BEING ASKED TO PROVIDE THE VIN SO THE IPC CAN BE ORDERED IN ADVANCE OF THE SCHEDULED APPOINTMENT. THIS WILL ELIMINATE THE NEED TO KEEP THE VEHICLE OVERNIGHT. DEALERS ARE TO OBTAIN THE VEHICLE MILEAGE WHEN SCHEDULING A SERVICE APPOINTMENT. THE VEHICLE MILEAGE WILL BE REQUIRED WHEN PLACING AN ORDER FOR THE IPC.
Condition
Some customers of all 2003-2004 model year and certain U.S. 2005 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge.
This special coverage covers the condition described above for a period of 7 years or 70,000 miles (110,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer.
For verified failures between 70,001 miles (110,001 km) and 80,000 miles (130,000 km) on U.S. vehicles, dealers are to provide the customer with an instrument panel cluster (IPC) only. Any additional costs, including labor to replace the instrument panel cluster, will be the responsibility of the customer. Dealers are responsible for the return of the customer's IPC back to the Electronic Service Center.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 28, 2007 for 2003-2004 model year vehicles, and March 23, 2009 for 2005 model year vehicles, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 28, 2007 for 2003-2004 model year vehicles, or March 23, 2009 for 2005 model year vehicles, must be submitted to the Service Contract provider.
Vehicles Involved
Involved are all 2003 and 2004 model year and certain U.S. 2005 Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles built within the following VIN breakpoints:
YEAR
DIVISION
MODEL
FROM
THROUGH
2003
Cadillac
Escalade
3R100001
3R320163
2004
Cadillac
Escalade
4R100006
4R323240
2005
Cadillac
Escalade
5R100001
5R199235
2003
Cadillac
Escalade ESV
3G117982
3G348029
2004
Cadillac
Escalade ESV
4G100001
4G343605
2005
Cadillac
Escalade ESV
5G100006
5G199627
2003
Cadillac
Escalade EXT
3G100002
3G343890
2004
Cadillac
Escalade EXT
4G100005
4G343604
2005
Cadillac
Escalade EXT
5G100009
5G199571
As far as the whining and front axle issues, you could have bearings failing in the front axle. It is just a matter of how far gone they are. I have seen minor scoring, and I have seen complete seizure. You can pull the front axle drain plug and check for metal, but first pull the fill plug and check that it was(is) at the proper level. You will get metal on the drain plug magnet, it is just a matter of how much. If it is exhibiting a condition known as 'crow hop', when you are turning the wheel and it feeds back through the steering wheel and scrubs tires, you could also have a condition in the transfer case that is causing it to drive the front/rear at same speeds.
Jan 27, 2010 at 2:41 PM
PAULY.G
i will take my truck in for the gauge cluster. Thank you for the information. I dont, however, think the bearings would just go all of a sudden like that. It usually has some signs first. One day it was fine, next day, whining! Is it possible the tach is the cause of that too? I figured maybe the computer is screwing it up by leaving the four wheel engaged. Make sense? Again, thank you for the help!
Jan 28, 2010 at 9:05 AM
FACTORYJACK
  • 4,159 POSTS
There are no computer influences on your transfer case, or axle. It is a single speed, 60/40 split, all wheel drive system. If it is whining with vehicle speed, something has happened mechanically.
Jan 28, 2010 at 2:58 PM
