My low headlights don't work. The high beams, parking and fog lights work fine. Any suggestions?
Jan 25, 2010 at 6:07 AM
FACTORYJACK
✓Experienced Mechanic
Check power and ground at the low beam connectors. Did one go out and then the other, or both at the same time? You could also swap the low with the hi relay. They have separate grounds but share the same relay.
