2003 Cadillac Escalade Ext HeadLights
2003 CADILLAC ESCALADE EXT
82,000 MILES • V8 • AWD • AUTOMATIC
DG92008
My low headlights don't work. The high beams, parking and fog lights work fine. Any suggestions?
Jan 25, 2010 at 6:07 AM
FACTORYJACK
  • 4,159 POSTS
Check power and ground at the low beam connectors. Did one go out and then the other, or both at the same time? You could also swap the low with the hi relay. They have separate grounds but share the same relay.
Jan 25, 2010 at 3:32 PM
