2003 Cadillac Escalade Ext electrical
85,000 MILES • V8 • 4WD • AUTOMATIC
TNICE
The passenger front door has no power(That in cludes the window, lock, mirror,and heated seat control)Ive checked fuses they look fine. The other doors are fine.what next
Sep 1, 2009 at 4:45 AM
FACTORYJACK
  • 4,159 POSTS
Just out of curiosity, does the keyless entry work? The passenger door module is the reciever, and it may be locked. You can try removing the pdm fuse from the left i/p fuse panel(behind the endcap), and reinstalling it to see if it clears. I am not certain if this will erase your keyless transmitter programming. If you try it, and it corrects your concerns, but you lose programming, reply and I can coach you through the programming of the transmitters.
Sep 1, 2009 at 4:11 PM
