2003 Cadillac Escalade Ext blower motor quit
EL PRESIDENTE'
2003 Cadillac Escalade Ext V8
Have power to blower. Fuses good. Any other tips? If not how to get blower out for replacement?
Jan 14, 2010 at 4:15 AM
FACTORYJACK
  • 4,159 POSTS
Do you have power AND ground at the blower? If you bridge the two wire blower connector with a test light, and it lights with the system on, you have a failed blower motor. There are 2 possible designs for blowers on your vehicle, a delphi blower, and a visteon blower. The first type has a cover to remove, a retaining tab to disengage, and you rotate counterclockwise. The visteon just has screws to remove. If you have no light when testing the connector, replace the blower control processor. It doesn't show that in the schematic, but the system may function by controlling the ground side, so it needs to be checked.
Jan 14, 2010 at 2:17 PM
