2002 Cadillac Escalade Ext SUSPENSION COMPRESSOR NOT WORKING
2002 CADILLAC ESCALADE EXT
103,000 MILES • 6 CYL • 4WD • AUTOMATIC
BROOKSW21
My compressor never turns on anymore. It used to turn on when I put the key in on occasion and would always turn on and suspension would lift up when I put weight on the back and put a trailer on.
I am wondering if their is a fuse to this or do you think I need to replace the suspension compressor? Thanks a lot
May 6, 2010 at 9:02 AM
FACTORYJACK
  • 4,159 POSTS
More than likely it is the compressor. There is a large connector near the compressor, I believe between the running board and the frame that has had some issues. Without a scan tool to simplify and command output of it, it is a guess at this point.
May 18, 2010 at 4:51 PM
