2002 Cadillac Escalade EXT SUSPENSION COMPRESSOR NOT WORKING
BROOKSW21
MEMBER
2002 CADILLAC ESCALADE EXT
6 CYL
4WD
AUTOMATIC
103,000 MILES
My compressor never turns on anymore. It used to turn on when I put the key in on occasion and would always turn on and suspension would lift up when I put weight on the back and put a trailer on.
I am wondering if their is a fuse to this or do you think I need to replace the suspension compressor? Thanks a lot
SPONSORED LINKS
Thursday, May 6th, 2010 AT 4:02 PM
FACTORYJACK
MECHANIC
More than likely it is the compressor. There is a large connector near the compressor, I believe between the running board and the frame that has had some issues. Without a scan tool to simplify and command output of it, it is a guess at this point.
