2007 Cadillac Escalade Esv Whistling noise while driving
55,000 MILES • V8 • AWD • AUTOMATIC
RONJOHN78
I notice a loud whistling noise while driving. However whenever I apply the brake regardless of speeds and how hard I hit the brakes the noise goes away.
Jun 7, 2010 at 10:03 PM
FACTORYJACK
  • 4,159 POSTS
This noise only occurs with vehicle speed, raising engine speed while stationary does not reproduce it? Your truck is equipped with a hydraulic brake boost system, meaning the assist comes from power steering hydraulics. See if at all, it can be reproduced when stationary, try with a combination of rpm increases, brake pedal pressure increases, and steering inputs. Also check the power steering fluid level. Your steering at full lock is going to create the greatest pressure increase. I have not seen a vehicle that matches the symptoms you've given. Does it sound like it could possibly be a wind whistle, and by pressing on the brake pedal you are changing the orifice that the wind is coming through? If it only occurs with vehicle speed, I would suspect that that may be the case. Has any mechanical repairs, body work etc..., been performed that may contribute to it's relevance?
Jun 8, 2010 at 2:05 PM
