2005 Cadillac Escalade Esv rear hatch door
65,000 MILES • V8 • AWD • AUTOMATIC
DEPENDABLE
rear hatch does not unlock with unlock buttons or opener it doesnt have any inside release how do i open it and what could the problem be?
Apr 29, 2009 at 7:46 AM
FACTORYJACK
  • 4,159 POSTS
It is kind of tricky, but you need to remove the trim panel from the door with it closed, access the lock actuator, physically unlock it, and the handle will release it then. I would check signal(power and ground) to the actuator lock solenoid, if it is present the solenoid failed. If you don't have a signal, you could have a faulty control which I think is from the Body Control Module, or wiring. The pass through, where the harness goes from the door to the body, is sometimes the sight of electrical issues.
Apr 29, 2009 at 2:29 PM
