2003 Cadillac Escalade Esv
2003 CADILLAC ESCALADE ESV
JAYWHITE
the drivers side door controls do not work. the windows button dont work,the automatic mirror, the door locks are all disabled but only on the drivers side. what can it be?
Jul 29, 2010 at 11:15 AM
HMAC300
  • 48,601 POSTS
check the relays and fuses first. that fusebox and relay boxes will be under the left side of the dash. But then if you don't find anything there make sure that you havn'e locked everything out with the lock switch on your door panel. Then it may be a switch or body module and will need a pro to check this out.
Sep 16, 2010 at 11:28 AM
