2007 Cadillac Escalade reset the coutermiles for the oil ch
INTERNATIONAL
  • 9 POSTS
I have a Cadillac Escalade 2007. After I changed the oil I need to reset the countermiles for the oil to start counting from 0 for a new oil. I have no Cadillac service in my country (Belarus), so I have to do it myself. Can you suggest me how to put it to 0 level?
I will be very grateful to you. Any of your help will be highly apprecated.
Thank you in advance.
Best regards,
Vadim
Oct 20, 2009 at 1:06 AM
FACTORYJACK
  • 4,159 POSTS
When you have oil life displayed on your drivers info center, press the button with just the check mark on it, and that should reset it.
Oct 20, 2009 at 6:01 PM
INTERNATIONAL
  • 9 POSTS
thank you very much for the prompt help! I will try it and hope it will work.
Thank you again for assistance!
My best regards,
Vadim
Oct 20, 2009 at 6:22 PM
INTERNATIONAL
  • 9 POSTS
Dear sirs, can you give me more detailed explanation of where this button is located? I tried to press some buttons, but didn't succeed. I will be very grateful to you.
Thank you again.
Best regards,
Vadim
Oct 20, 2009 at 11:57 PM
FACTORYJACK
  • 4,159 POSTS
You should have a set of buttons with icons on them. One is a picture of a road, one is a vehicle with an 'I' next to it, one has two boxes followed by two underscores(the upper square has a check mark in it), and the lowest one has a check mark only on it. These are for your drivers info center. The vehicle with the 'I' next to it is vehicle info, this should scroll you to oil life. Pressing the one with the check mark will reset the oil life percentage, as long as oil life XXX% is displayed. If you have an owners manual, it will describe it under the instrument panel section. Here is the info from the manual, it don't display images, just text:
DIC Operation and Displays
The DIC has different displays which can be accessed by pressing the DIC buttons located on the instrument panel, next to the steering wheel.
The DIC displays trip, fuel, and vehicle system information, and warning messages if a system problem is detected. A digital speedometer also appears at the bottom of the DIC display. The digital speedometer can be enabled or disabled. See "DISPLAY DIGITAL SPEED" under DIC Vehicle Customization for more information.
DIC Buttons
The buttons are the trip/fuel, vehicle information, customization, and set/reset buttons. The button functions are detailed in the following pages.
(Trip/Fuel): Press this button to display the odometer, trip odometer, fuel range, average economy, fuel used, timer, and transmission temperature.
(Vehicle Information): Press this button to display the oil life, units, tire pressure readings for vehicles with a Tire Pressure Monitor (TPM) system, Tire Pressure Monitor (TPM) system programming for vehicles with a TPM system, and Remote Keyless Entry (RKE) transmitter programming.
(Customization): Press this button to customize the feature settings on your vehicle. See DIC Vehicle Customization for more information.
(Set/Reset): Press this button to set or reset certain functions and to turn off or acknowledge messages on the DIC.
Trip/Fuel Menu Items
(Trip/Fuel): Press this button to scroll through the following menu items:
Odometer
Press the trip/fuel button until ODOMETER displays. This display shows the distance the vehicle has been driven in either miles (mi) or kilometers (km).
To switch between English and metric measurements, see "Units" later in this section.
Trip Odometer
Press the trip/fuel button until TRIP displays. This display shows the current distance traveled in either miles (mi) or kilometers (km) since the last reset for the trip odometer.
The trip odometer can be reset to zero by pressing the set/reset button while the trip odometer is displayed.
Fuel Range
Press the trip/fuel button until FUEL RANGE displays. This display shows the approximate number of remaining miles (mi) or kilometers (km) the vehicle can be driven without refueling. The display will show LOW if the fuel level is low.
The fuel range estimate is based on an average of the vehicle's fuel economy over recent driving history and the amount of fuel remaining in the fuel tank. This estimate will change if driving conditions change. For example, if driving in traffic and making frequent stops, this display may read one number, but if the vehicle is driven on a freeway, the number may change even though the same amount of fuel is in the fuel tank. This is because different driving conditions produce different fuel economies. Generally, freeway driving produces better fuel economy than city driving. Fuel range cannot be reset.
Average Economy
Press the trip/fuel button until AVERAGE ECONOMY displays. This display shows the approximate average miles per gallon (mpg) or liters per 100 kilometers (L/100 km). This number is calculated based on the number of mpg (L/100 km) recorded since the last time this menu item was reset. To reset AVERAGE ECONOMY, press and hold the set/reset button.
Fuel Used
Press the trip/fuel button until FUEL USED displays. This display shows the number of gallons (gal) or liters (L) of fuel used since the last reset of this menu item. To reset the fuel used information, press and hold the set/reset button while FUEL USED is displayed.
Timer
Press the trip/fuel button until TIMER displays. This display can be used as a timer.
To start the timer, press the set/reset button while TIMER is displayed. The display will show the amount of time that has passed since the timer was last reset, not including time the ignition is off. Time will continue to be counted as long as the ignition is on, even if another display is being shown on the DIC. The timer will record up to 99 hours, 59 minutes and 59 seconds (99:59:59) after which the display will return to zero.
To stop the timer, press the set/reset button briefly while TIMER is displayed.
To reset the timer to zero, press and hold the set/reset button while TIMER is displayed.
Transmission Temperature
Press the trip/fuel button until TRANS TEMP displays. This display shows the temperature of the automatic transmission fluid in either degrees Fahrenheit (°F) or degrees Celsius (°C).
Blank Display
This display shows no information.
Vehicle Information Menu Items
(Vehicle Information): Press this button to scroll through the following menu items:
Oil Life
Press the vehicle information button until OIL LIFE REMAINING displays. This display shows an estimate of the oil's remaining useful life. If you see 99% OIL LIFE REMAINING on the display, that means 99% of the current oil life remains. The engine oil life system will alert you to change your oil on a schedule consistent with your driving conditions.
When the remaining oil life is low, the CHANGE ENGINE OIL SOON message will appear on the display. See "CHANGE ENGINE OIL SOON" under DIC Warnings and Messages . You should change your oil as soon as you can. See Engine Oil . In addition to the engine oil life system monitoring the oil life, additional maintenance is recommended in the Maintenance Schedule in this manual. See Scheduled Maintenance for more information.
Remember, you must reset the OIL LIFE display yourself after each oil change. It will not reset itself. Also, be careful not to reset the OIL LIFE display accidentally at any time other than when the oil has just been changed. It cannot be reset accurately until the next oil change. To reset the engine oil life system, see Engine Oil Life System .
Units
Press the vehicle information button until UNITS displays. This display allows you to select between English or Metric units of measurement. Once in this display, press the set/reset button to select between ENGLISH or METRIC units. All of the vehicle information will then be displayed in the unit of measurement selected.
Tire Pressure
If your vehicle has a Tire Pressure Monitor (TPM) system, the pressure for each tire can be viewed in the DIC. The tire pressure will be shown in either pounds per square inch (psi) or kilopascals (kPa). Press the vehicle information button until the DIC displays FRONT TIRES PSI (kPa) LEFT ## RIGHT ##. Press the vehicle information button again until the DIC displays REAR TIRES PSI (kPa) LEFT ## RIGHT ##.
If a low or high tire pressure condition is detected by the system while driving, a message advising you to check the pressure in a specific tire will appear in the display. See Inflation - Tire Pressure and DIC Warnings and Messages for more information.
If the tire pressure display shows dashes instead of a value, there may be a problem with your vehicle. If this consistently occurs, see your dealer/retailer for service.
Relearn Tire Positions
If your vehicle has a Tire Pressure Monitor (TPM) system, after rotating the tires or after replacing a tire or sensor, the system must re-learn the tire positions. To re-learn the tire positions, see Tire Pressure Monitor System . See Tire Inspection and Rotation and DIC Warnings and Messages for more information.
Relearn Remote Key
This display allows you to match Remote Keyless Entry (RKE) transmitters to your vehicle. To match an RKE transmitter to your vehicle, do the following:
Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays.
Press the set/reset button until REMOTE KEY LEARNING ACTIVE is displayed.
Press and hold the lock and unlock buttons on the first transmitter at the same time for about 15 seconds.
On vehicles with memory recall seats, the first transmitter learned will match driver 1 and the second will match driver 2.
A chime will sound indicating that the transmitter is matched.
To match additional transmitters at this time, repeat Step 3.
Each vehicle can have a maximum of eight transmitters matched to it.
To exit the programming mode, you must cycle the key to LOCK.
Blank Display
Oct 21, 2009 at 5:22 PM
