2006 Cadillac Escalade Front Brake Bolt
2006 CADILLAC ESCALADE
CADMAN06
Brakes problem
2006 Cadillac Escalade V8 Four Wheel Drive Automatic 50k miles
What is the size for the front caliper bolt ? Actually I am looking for the tool to remove the bolts.
Thank you
Aug 29, 2009 at 3:52 AM
HMAC300
  • 48,601 POSTS
Those are special bolts and shouldn't be replaced with any old bolt. If it is not a normal bolt head it will be either a Torx bit or allen bit. Both of them are available at any auto parts store. It should be a 50-55-60 size or maybe a 10mm allen wrench.
Oct 27, 2009 at 8:58 AM
FACTORYJACK
  • 4,159 POSTS
The bolts that hold the caliper to the bracket are 15mm head. The bolts that hold the bracket to the knuckle are 18mm head, or possibly 15mm.
80 ft lbs torque on the caliper guide pin bolts
129 ft lbs torque on the bracket bolts
Oct 27, 2009 at 4:45 PM
