2005 Cadillac Escalade
DOC1301
  • 2005 CADILLAC ESCALADE
Electrical problem
2005 Cadillac Escalade V8 Automatic 70128 miles
How to chnage the daytime running light on the driver's side?
Friday, March 19th, 2010 AT 8:38 PM
FACTORYJACK
  • 4,159 POSTS
Remove the push pin retainers from the upper radiator shield, remove the 1 bolt at the center of the grill, and pull out on the upper right and left corners to release the clips. Pull out and up on the grill to remove. There are 2 L shaped rods that hold the headlight assembly in, release them from the tabs and pull them out. Wiggle the headlamp assembly out, remove the rubber seal behind the DRL port, twist the socket to dislodge, and replace bulb.
Friday, March 19th, 2010 AT 11:26 PM
