2004 Cadillac Escalade mounting bolts
DALLIS
Brakes problem
2004 Cadillac Escalade V8 Two Wheel Drive Automatic
I'm tryng to locate mounting bolts for the calibar, there are 2 bolts that mount the calibar to plate behind rotor, sorry for spelling :-)
Oct 12, 2009 at 5:30 AM
HMAC300
  • 48,601 POSTS
if you can find the two bolts that mount the caliper then if you go up by the wheel there should be one at each end of the caliper. Often times they will look like they are mounted in rubber or have rubber around them to keep the dirt out.
Oct 27, 2009 at 8:42 AM
