2003 Cadillac Escalade OVERHEATING
90,000 MILES • V8 • 2WD • AUTOMATIC
ADDIESGMA
My heater has been working sporadically. When it isnt working the temperature gauge starts to go up. If the heater kicks in and starts working the temperature gauge goes down.
Nov 13, 2009 at 3:32 AM
HMAC300
  • 48,601 POSTS
no heat is a classic exmple of being low on coolant. You may have intake gaskets leaking. Take it to a pro and have them pressure check the system. You hae to be leaking coolant out in order for it to go down. then you get no heat......
Jan 13, 2010 at 10:47 AM
