2003 Cadillac Escalade lights
2003 CADILLAC ESCALADE
63,181 MILES • V8 • AWD • AUTOMATIC
PBLACKN
when turning on left hand signal, the flashers on rear view mirrors both come on and flash ..when turning on the right hand signal that works correctly. Also, a message on the dash stays on the dash "service ride control" I don't know what that means? I had some wheel bearing replaced.
Oct 28, 2010 at 12:00 AM
FACTORYJACK
  • 4,159 POSTS
The mirrors are on separate circuits and individual fuses. The power to those fuses originates at the turn signal/flasher module. I would not suspect a multifunction switch, but it is possible. I would suspect that flasher module, as it has internal logic. Are you certain that it is only the mirror indicators, and not all the turn bulbs? Looking at the schematic, in theory all should be coming on.
The service ride control is not associated with a wheel bearing. It would include automatic level control, and electronic suspension control. Do you hear your level control compressor come on after keying the vehicle up?
Oct 28, 2010 at 3:20 PM
