My Escalade's engine is dying, don't know where to start. Please advise. Thank you!
Aug 16, 2010 at 11:17 AM
HMAC300
✓ASE Certified Mechanic
when does it die? when you come to a stop? change your fuel filter, check your fuel pressure. then get some choke cleaner and spray both sides of the throttle plate as they gunk up with oil. see if that helps. your fuel pressure should be 40p.s.i. minimum.....
Sep 1, 2010 at 6:18 PM
