2003 Cadillac Escalade
2003 CADILLAC ESCALADE
165,000 MILES • V8 • AWD • AUTOMATIC
MJHESS81
A light has popped up on my dash that says service drive train. What does this mean? Is it something major, or an easy fix?
Jun 25, 2009 at 2:36 PM
FACTORYJACK
  • 4,159 POSTS
The reason I forwarded this is to illustrate there is no service drive train message. Scroll through the list and pick the warning message that is being displayed, or ultimately, you will need a diagnostic scan tool connected to the vehicle, and fault codes read. That will provide some direction to assist you in.
DIC Warning Messages
Symbol
Description
BATTERY NOT CHARGING
Refer to Charging System Description and Operation in Engine Electrical
CHANGE ENGINE OIL
Refer to Indicator/Warning Message Description and Operation
CHECK ENGINE OIL LEVEL
CHECK WASHER FLUID
Refer to Wiper/Washer System Description and Operation in Wiper/Washer System
CARGO DOOR AJAR
Refer to Cargo Door Description and Operation in Body Rear End
DOOR AJAR - DRIVER
Refer to Door Ajar Indicator Description and Operation in Doors
DOOR AJAR - LEFT REAR
DOOR AJAR - PASSENGER
DOOR AJAR - RIGHT REAR
ENGINE COOLANT HOT
Refer to Cooling System Description and Operation in Engine Cooling
ENGINE OVERHEATED
FUEL LEVEL LOW
ICE POSSIBLE
LOW COOLANT
OIL PRESSURE LOW
OVERSPEED
PROGRAM CLUSTER
REAR ACCESS OPEN
REDUCED ENGINE POWER
Refer to
• Powertrain Control Module Description in Engine Controls - 4.8L, 5.3L and 6.0L
• Powertrain Control Module Description in Engine Controls - 8.1L
RFA X BATTERY LOW
Refer to Keyless Entry System Description and Operation in Keyless Entry
SECURITY
Refer to Theft Systems Description and Operation in Theft Deterrent
SERVICE 4 WHEEL STEER
Refer to Rear Wheel Steering Description and Operation in Rear Wheel Steering
SERVICE 4WD
Refer to
• Transfer Case Description and Operation in Transfer Case - BW 4481-NR3
• Transfer Case Description and Operation in Transfer Case - BW 4482-NR4
• Transfer Case Description and Operation in Transfer Case - NVG 246-NP8
SERVICE AIR BAG
Refer to SIR System Description and Operation in SIR
SERVICE BRAKE BOOSTER
Refer to Brake Warning System Description and Operation in Hydraulic Brakes
SERVICE BRAKE SYSTEM
SERVICE RIDE CONTROL
Refer to Electronic Suspension Control Description and Operation in Electronic Suspension Control (ESC)
SERVICE STABILITY SYSTEM
Refer to ABS Description and Operation in Antilock Brake Systems
STABILITY SYSTEM ACTIVE
STABILITY SYSTEM DISABLED
STABILITY SYSTEM LIMITED
TRACTION ACTIVE
TRACTION SYSTEM LIMITED
TRANS HOT IDLE ENGINE
Refer to Transmission Indicators and Messages in Automatic Transmission - 4L60-E
TRANS IN WARM UP
TRANSMISSION HOT
TURN SIGNAL ON
Refer to Exterior Lighting Systems Description and Operation in Lighting Systems
VEHICLE SPEED LIMITED
Jun 25, 2009 at 9:51 PM
