2003 Cadillac Escalade
2003 CADILLAC ESCALADE
125,000 MILES • V8 • AWD • AUTOMATIC
VIC229
Hi my a/c was not working we checked and it was my compressor i got a new compressor oifice tube
and a new accumulator and my rear a/c is very cold but the front was cold for about 10 minutes and now is only blowing air but the rear is cold.
May 22, 2009 at 12:50 PM
TINY LEE
use dura flush or you may have a blend door problem
Oct 23, 2018 at 5:16 AM
FACTORYJACK
  • 4,159 POSTS
It is possible that the metal was not fully removed, and the front orifice tube is restricted again. Having a rear unit, it has two expansion devices. You might have it pulled down, and check the front tube. Otherwise, you may have a blend actuator issue and some diagnosis would be needed.
