2002 Cadillac Escalade u joints or driveshaft
176,000 MILES • V8 • 4WD • AUTOMATIC
CLOCKHART
when i put car in drive it goes forward but make a bump like grind noise when i put it in reverse i make clicking and bumping noise like it wants to stop
Apr 2, 2008 at 10:38 AM
BMRFIXIT
  • 19,053 POSTS
check u joint
check brakes
check differential
Apr 2, 2008 at 11:23 AM
BUZZSAW
  • 1,198 POSTS
[quote:e1c4c240d2="clockhart"]2002 Cadillac Escalade V8 Four Wheel Drive Automatic 176000 miles
when i put car in drive it goes forward but make a bump like grind noise when i put it in reverse i make clicking and bumping noise like it wants to stop[/quote:e1c4c240d2]
this could be a normal condition, to help it you need to lube the slip joint in the drive shaft, its probally dry from not getting greased, or the carrier bearing is bad
Apr 3, 2008 at 8:13 PM
