2002 Cadillac Escalade Stability Control System
91,000 MILES • V8 • AWD • AUTOMATIC
WALTER7514
My Escallade EXT keeps giving me a "Service Stability System" message on the message screen on the dashboard. I had the same problem last year, and the dealer found trouble codes C0205.207 stored in the system. They checked the reading from the "Steering Wheel Position" and found an internal malfunction in the "Steering Wheel Position Sensor."
QUESTION: What's going on? Is it likely that the same sensor has failed...after just one year and 3,000 miles? Do you know of any systemic problems with this model of the Escalade...and can you point me in the right direction...other than back to the dealer?
If I purchased one of the better OBDII readers...will it really help me solve the problem?
Thanks,
Phil
Jan 7, 2008 at 12:38 AM
2CARPRO JACK
  • 11,533 POSTS
Did your new reader find any codes? Not likely that it is the same problem, but the PCM sees something it doesnt like and if your scanner wont read the code/codes, you will need to find a shop that can.
Feb 28, 2019 at 11:07 AM
