2002 Cadillac Escalade Reduce engine power
14,500 MILES • V8 • AWD • AUTOMATIC
MERIIO13
I have a 02 escalde the problem I'm having is when I turn it on computer message says reduce engine power also it says stubility systum when I try to push the gas pedle the rpm does not go up
Nov 3, 2009 at 10:39 AM
FACTORYJACK
  • 4,159 POSTS
That is usually in response to a fault with the drive-by-wire, or throttle actuator control system. What you are experiencing is limp-home mode. There is no sure-shot cause for this. It will have code(s) in the system, possible that you have a faulty throttle unit, or accelerator pedal position sensor fault. Both of these items house two sensors that cross check each other.
Nov 4, 2009 at 2:23 PM
