2002 Cadillac Escalade
HILLARYRG80
tried starting my car, NOTHING turned on, no lights, no radio. Ten minutes later tried turnig car on and all lights and everything worked but car was chuckling, I tried to give it gas, but it didn't do anything, then the car stayed on fine, but wouldn't drive. I just changed the battery five months ago
Jan 11, 2010 at 12:09 PM
HMAC300
  • 48,601 POSTS
this problem could be a battery problem. You need to take it to a pro where he can check to see if any wiring is loose or if the vehicle is charging ok. If it's not charging the battery will go down in power and screw wverything up.
Jan 13, 2010 at 10:31 AM
