2000 Cadillac Escalade what to do?
2000 CADILLAC ESCALADE
268,000 MILES • V8 • 4WD • AUTOMATIC
DANDBOWTIE
I am replaceing th eac compressor and dryer and I need to know what to do after i have put on all the stuff, like where I need to add oil, and what to check to make sure I got everything ready for refrigerant?
Aug 14, 2009 at 2:34 AM
DOCFIXIT
  • 18,828 POSTS
With old compressor off pour out oil if lees than 2oz. add 4oz to new compressor. Accumulator 2oz. oil. System oil is 8 oz. there will be oil left in Evap., condensor and lines. Recommend orfice tube especialy if old compressor shelled. Oil all O rings and threaded connections. Button up put on Vacuum pump for at least 2 hrs a little longer vwould not hurt.
Close gagues shut off pump let set 2 hrs. if no loss of vac then charge. 2lbs of 134A
Aug 14, 2009 at 6:47 AM
