2000 Cadillac Escalade rear drive/ differential
2000 CADILLAC ESCALADE
16,100 MILES • V8 • 4WD • AUTOMATIC
BTEXPRES1
While driving it felt as if I hit a pothole and then my vehicle would not respond pressing the gas. It does rev the engine but the truck does not move. Once I placed it in park, the vehicle continued to roll. The shaft connected to the rear wheels turns but the rear wheels do not move. Is this a differential problem. Should I just replace the "rear" ? How much and is it worth it?
Jan 26, 2009 at 2:43 AM
FACTORYJACK
  • 4,159 POSTS
You at least need to have the rear diff cover removed to assess the damage. Were there any symptoms leading up to this? It will probably run near $1000 to fix, I would guess.
Jan 29, 2009 at 3:50 PM
