2000 Cadillac Escalade
FREDY
Electrical problem
The starter isnt getting a good current from the battery. The battery terminals just look bad and I want to get new ones. What should I look for when buying them and how do I change them?
Mar 14, 2010 at 4:14 AM
HMAC300
  • 48,601 POSTS
if the terminals look bad the cable may be corroded as well. Just replace the cable as it would be easier and cheaper for you to do this. Just make sure to disconnect it from the battery first. Always disconnect the negative cable first...
Mar 20, 2010 at 5:49 AM
FREDY
Thank you
Mar 22, 2010 at 1:58 PM
