I need to change the Camshaft Position Sensor but I cant find it where is it? Also is the ECM and PCM the same part or are they different?
Jul 5, 2009 at 9:27 AM
HMAC300
✓Experienced Mechanic
The cam sensor should be at the front top of the engine. It might be hard to see it will have a either a 8mm head bolt or 10mm head bolt holding it in. ECM means Engine Control Module and PCM means Powertrain Control Module. Yes they are the same.
Oct 27, 2009 at 9:03 AM
