2000 Cadillac Escalade
CRAPPYVAN1
there is coolant leaking from the rear of my engine what do u think the problem could be?
Oct 17, 2009 at 3:30 AM
HMAC300
  • 48,601 POSTS
you really need to take this toa pro where he can put a pressure tester on it. the leak can be a bad heater hose, leaking head gasketor even a heater core..
Oct 27, 2009 at 8:39 AM
FACTORYJACK
  • 4,159 POSTS
More than likely a leaking intake manifold, they usually start leaking at the ends where the head cooling passages are. gasket just deteriorates. A pressure test is recommended.
Oct 27, 2009 at 4:50 PM
