WHAT CAUSES HIGH PITCHED WHINING NOISE, SEEEMS TO BE CONSTANT, SEEMS TO COME FROM REAR OF VEHICLE
Jan 30, 2009 at 10:13 PM
FACTORYJACK
✓Experienced Mechanic
Is the noise present with vehicle speed, or engine speed, and does it change or remain a constant ring? The only thing that comes to mind at this point is the fuel pump. You may even hear it briefly when keyed up prior to starting. Pretty common on C/K trucks, does not necessarily indicate failing.
