1999 Cadillac Escalade Disconnecting brake booster from bra
139,000 MILES • V8 • 4WD • AUTOMATIC
GJETT95008
Replacing the brake booster requires disconnecting the pin from the brake pedal.
Unfortuately access is blocked by the steering column.
Do I have to drop/remove the steering column, remove the dash and go in that way???
Easy repair made difficult..
Thanks
Gary
Dec 4, 2009 at 7:15 AM
FACTORYJACK
  • 4,159 POSTS
I am not showing anything extra in the procedure. The retainer that holds the brake switch can be removed, it is a bit of a challenge though.
Dec 7, 2009 at 2:07 PM
