1999 Cadillac Escalade
KENIF508
i've been having an electrical problem with the windows, wipers, and radio all not working. I checked the fuses that didn't work how do I fix it?
Oct 29, 2010 at 7:17 AM
WRENCHTECH
  • 20,760 POSTS
Your probably having some issues with the Body Control Module. Your going to need a Tech2 scan tool to be able to diagnose anything. If it gets replaced, it also has to be programmed so it looks like your off to the dealer on that one.
Oct 29, 2010 at 7:43 AM
FACTORYJACK
  • 4,159 POSTS
Get a little more specific if you would. Windows, are they all inoperative, do some work and not others, if it is all inoperative from the master switch, what about respective switches?
Wipers, do they operate in any mode, do they park?
Radio, is it display with no audio, no audio or display, etc...?
Oct 30, 2010 at 9:23 AM
WRENCHTECH
  • 20,760 POSTS
I can't be more specific. This is a sophisticated, computer controlled system. You are way over your head here and do not have the equipment required for this diagnosis.
Oct 30, 2010 at 9:33 AM
