white smoke from exhaust-sometimes
CADILLAC ELDORADO
BRUNO1953
I have a 97 Cadillac Eldorado, V8, 4.6 Northstar engine.
last week the Service Engine light came on. I noticed some white smoke from exhaust.
It's been 3 days, no more white smoke, light still on.
No overheating, no coolant low message, oil seems fine.
Is this a gasket problem?
Thank You.
Jun 9, 2007 at 9:29 AM
SERVICE WRITER
  • CAR REPAIR CONTRIBUTOR
  • 9,123 POSTS
The Northstar engine is common for headgasket troubles. Are you losing coolant?
Jun 9, 2007 at 9:37 AM
BRUNO1953
No coolant loss noted.
Jun 9, 2007 at 9:51 AM
SERVICE WRITER
  • 9,123 POSTS
well thats a good sign. You need to get the codes pulled to see what's up with the CEL
Jun 9, 2007 at 11:46 AM
CHARLESTMOSS
[quote:a94cc19db6="Service Writer"]The Northstar engine is common for headgasket troubles. Are you losing coolant?[/quote:a94cc19db6]
Jun 27, 2007 at 6:37 PM
SERVICE WRITER
  • 9,123 POSTS
Different ways to go about it. Leak is internal of external. You can pressure test it, where the system is put under pressure and monitored for pressure loss and visual checking externally. You can pull the plugs at this point and see if coolant is leaking into the cylinders, if no external leak was found that is. OR you can use a chemical that is added to the cooling system and will change colors of exhasut fumes or in cooling system.
Jun 27, 2007 at 7:29 PM
