The fault lies not with the heads, but the bolt threads in the block. It should be determined that an internal leak exists before worst case is assumed. A cooling system pressure test, as well as a block test for combustion gases in the radiator can confirm a leak. If it is determined that an internal leak exists, the block can be repaired with thread inserts.
SPONSORED LINKS
Sunday, January 10th, 2010 AT 11:30 PM
