2000 Cadillac El Dorado How to get the blower motor out
2000 CADILLAC ELDORADO
168,000 MILES • 6 CYL • FWD • AUTOMATIC
MRSHAAS
I have the new blower motor for my car but the car we took it off had a trap door to get it out and my car does not. How do I get it in?
Oct 27, 2010 at 5:44 AM
WRENCHTECH
  • 20,761 POSTS
Bulletin No.: 03-01-37-002
Date: November 19, 2003
INFORMATION
Subject:
Revised HVAC Blower Motor Installation Procedures
Models:
1994-1997 Cadillac Seville
1994-1999 Cadillac DeVille
1994-2002 Cadillac Eldorado
The intent of this bulletin is to provide technicians information regarding the proper installation of the Heating, Ventilation and Air Conditioning (HVAC) Module blower motor (with impeller) assembly.
The current available HVAC Module blower motor for the above listed vehicles can be identified by the three mounting holes (1). The original equipment blower motor had five mounting holes.
In order to avoid confusion and ensure a high level of customer satisfaction, when replacing an HVAC Module blower motor, refer to this bulletin for the appropriate procedure.
DeVille-HVAC Blower Motor
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Removal Procedure
1. Disconnect the negative battery cable.
2. Remove the cross-car brace.
3. Disconnect and position the ignition control module assembly out of the way.
4. Position the cross-car harness out of the way.
5. Remove the solenoid purge valve.
6. Remove the blower motor.
^ Disconnect connector from the blower motor.
^ Remove the blower motor screws (either 3 or 5 screws).
^ Remove the blower motor from the HVAC Module.
1. If present, remove the 2 ribs located on the barrier. Refer to Step 3 and the illustrations in the Instruction Sheet, P/N, 52494110, found in the blower motor kit.
Important: Ensure the blower motor gasket makes a complete seal around the blower motor.
2. Install the new blower motor with heat shield. Refer to Steps 4 and 5 in the Instruction Sheet, P/N 52494110, found in the blower motor kit.
3. Install the blower motor retaining screws.
Tighten
Tighten the screws to 4 N.m (35 lb in).
4. Tighten the lower heat shield retaining screws to 4 N.m (35 lb in).
5. Connect the connector to the blower motor.
6. Install the solenoid purge valve.
7. Reposition and connect the ignition control module assembly.
8. Install the cross-car brace.
9. Connect the negative battery cable.
Eldorado/Seville-HVAC Blower Motor
Removal Procedure
2. Remove the camshaft cover.
3. Remove the blower motor.
1. If present, remove the 2 ribs located on the barrier. Refer to Step 3 and the illustrations in the Instruction Sheet, P/N 52494110, found in the blower motor kit.
Tighten
6. Install the camshaft cover.
7. Connect the negative battery cable.
Oct 27, 2010 at 5:50 AM
