2000 Cadillac El Dorado
74,000 MILES • V8 • 4WD • AUTOMATIC
ZGIRL24
While driving, engine will cut off. It takes 15-30 minutes for it to restart. Service engine light comes on and then goes back off.
Dec 17, 2007 at 4:54 AM
PETE.HEPP
same happened to mee several times. Took to dealer said cam sensor not working, fixed, no problems since.
Jan 31, 2008 at 12:11 AM
BUZZSAW
  • 1,198 POSTS
[quote:2041bbc300="zgirl24"]Engine problem
2000 Cadillac El Dorado V8 Four Wheel Drive Automatic 74000 miles
While driving, engine will cut off. It takes 15-30 minutes for it to restart. Service engine light comes on and then goes back off.[/quote:2041bbc300]
pull the codes, off and down on the mode button at the same time, with key in the on posision, it could also be the crank sensors
Jan 31, 2008 at 2:55 AM
