Driver side blowes out heat and passenger side blowes out a/c when a/c is turned on.
Wednesday, July 14th, 2010 AT 10:31 AM
FACTORYJACK
MECHANIC
Check the actuator, lower one on the RH side. If the actuator is not moving, it could be the actuator or the programmer. You can also disconnect the linkage rod and move it to see that the door is not bound.
