1999 Cadillac El Dorado engine hesitation
103,000 MILES • V8 • FWD • AUTOMATIC
DBRSHOGAN
the engine hesitates and sputters at low speed acceleration. the fuel gauge also acts funny (Goes up and down over an hour or so driving. I believe it's the fuel pump/sending unit in the gas tank, but don't know for sure.
Any suggestions?
Apr 6, 2010 at 6:54 AM
  • 75,988 POSTS
Hi dbrshogan, Welcome to 2carpros and TY for the donation.
Your probable causes here could be one of the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
_________________
Apr 6, 2010 at 7:01 AM
