1998 Cadillac El Dorado floor shifter
KJCAD
Transmission problem
1998 Cadillac El Dorado Front Wheel Drive Automatic
shifting out of park to drive after car is shut off and re started is very hard. after car has ran a while shifter gets better.
Nov 19, 2009 at 11:37 AM
FACTORYJACK
  • 4,159 POSTS
Is it hard to push the button in on the shifter handle? I had one awhile back that was that way, I believe it was older than 98. Never had a resolution, it appeared that overcoming the magnetism of the brake/trans shift interlock soleno was the issue. The solenoid was only available with the shifter, and the shifter was discontinued. I had replaced it with a used shifter that seemed to work, but the customer disagreed. I tried lubing with no success.
Nov 19, 2009 at 1:13 PM
