1998 Cadillac El Dorado Alternator
123,000 MILES • V8 • FWD • AUTOMATIC
JOE GIG
Message center will indicate "battery not charging" when I start the car in the a.m. After driving a few minutes, the alternator kicks in and the battery begins charging (14.0-14.5). With several starts during the day everything runs normally.
Next a.m., again the "battery not charging" appears again until the car is driven about a mile. I have had all electrical checked out...Should the alternator be replaced or is there another solution?
Mar 16, 2008 at 10:36 AM
BUZZSAW
  • 1,198 POSTS
[quote:97ea53379e="Joe Gig"]Electrical problem
1998 Cadillac El Dorado V8 Front Wheel Drive Automatic 123000 miles
Next a.m., again the "battery not charging" appears again until the car is driven about a mile. I have had all electrical checked out...Should the alternator be replaced or is there another solution?[/quote:97ea53379e]
pull codes, off and warmer on the heater controls, w/ the key in the on position, post them here
you might have the brushes in the alt going bad, lets see what codes you have
Mar 16, 2008 at 11:10 AM
