1998 Cadillac El Dorado ac 10amp fuse blows
1998 CADILLAC ELDORADO
95,600 MILES • V8 • FWD • AUTOMATIC
CADDYMAN 1
check eng lite on code #1660 cooling fans quit
Jul 24, 2009 at 1:37 PM
  • 110,244 POSTS
This is a cooling fan circuit code that indicates a problem. Does the fuse blow when the fans stop working? Also, have you checked the fan's to see if they are drawing too many amps? A bad motor could cause this. Also, have you checked wiring to make sure there are no shorts, broken wires, or bad grounds?
Jul 24, 2009 at 3:16 PM
