1997 Cadillac El Dorado Tail Light
1997 CADILLAC ELDORADO
149,000 MILES • V8 • FWD • AUTOMATIC
NICKC77
My passenger side tail light is not working, when my automatic lights are on. My signal and brake light is working. I have changed the bulb and still not working.
Apr 5, 2009 at 4:38 AM
FACTORYJACK
  • 4,159 POSTS
All three bulbs on the rh rear are out, or at least no taillights?, do you have a rh front amber park lamp? Check the rh park fuse, lift the door on the underhood fuse panel and see if it is there. If it is not, it is in the rear block in the trunk, under the insulation that covers the parcel shelf and rear seat back. Just lift the left lower corner out, and you should find the fuses with a legend beside it.
Apr 5, 2009 at 5:18 AM
