1997 Cadillac El Dorado idle is to high
113,454 MILES • V8 • FWD • AUTOMATIC
CHAMMER85
my engines idle is to high i have replace the tps sensor, iac, and the trottle body gaskets can you help me?
Dec 9, 2009 at 2:36 AM
BLACKOP555
  • 10,386 POSTS
disconnect battery and let computer reset and see if that fixes it. if not its time to check for vaccum leaks. did you just notice this all of a sudden?
start engien and spray the lines and around gaskets. if idle changes then you have a vaccuum leak
Dec 9, 2009 at 1:02 PM
