1996 Cadillac El Dorado theft system problem
12,209 MILES • V8 • FWD • AUTOMATIC
FACHONPEACOCK
Ok my car when u turn the key coding is saying that the car may not restart theft system problem im wondering like every one else what could that be and is there a way that i could reset this or maybe even disable the cars security system
Jul 8, 2009 at 12:12 PM
FACTORYJACK
  • 4,159 POSTS
You more than likely have broken wires at the ignition cylinder. The proper method of repair is to have the cylinder replaced. You can bypass the system, if you know your key value, and find the two small white wires in an orange conduit, at te lower column electrical connector. Substitute the key with resistors of same value across the terminals.
Jul 8, 2009 at 2:29 PM
