1996 Cadillac El Dorado stutter or "fishbite at cruisn
151,000 MILES • V8 • FWD • AUTOMATIC
KHUSSEY
Get an intermitant slight tug or studder once the car is at cruising speed with or without the cruise control on.
Have already done the following
Added Fuel conditioner
Changed plugs and wires
Changed FPR
Cleaned Throttle Body
Cleaned PCV Valve
Checked for Arching
Could it be an EGR.TPS Coil ?
Aug 6, 2008 at 8:12 AM
MERLIN2021
  • 17,250 POSTS
Check MAF and fuel pressurer, follow this link for fuel testing, autozone rents the tool and refunds all money when the tool is returned.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Aug 6, 2008 at 8:23 AM
JETSA
  • 117 POSTS
Doubtful on EGR or TPS. My guess would be TCC (torque convertor) engaging and disengaging at the wrong time. This is generally referred to as "fishbite" as you so well stated. Transmission repairs such as this could get quite costly. Make sure whoever you take it to knows Cadillac transmissions.
Aug 8, 2008 at 5:25 PM
