right turn there is a clicking noise?
62,696 MILES • V8 • FWD • AUTOMATIC
PFHFLYBOY
When I make a right turn and only a right turn there is a clicking noise in my left front wheel. I have taken the tire, caliber, and rotor off and can find no witness marks.
Dec 7, 2007 at 11:19 PM
MERLIN2021
  • 17,250 POSTS
You want to check the CV-Joints, even if the boot is not torn, clicking while turning is the indicator of a bad joint!
Dec 7, 2007 at 11:40 PM
  • 55,673 POSTS
Yep, the CV drive axle can cause this issue. Here is how to change it out to help fix the problem.
REMOVAL
1. Raise and support vehicle, then remove tire and wheel assembly.
2. Install a brass drift or a screwdriver to prevent the rotor from turning, Fig. 7 .
3. Remove axle nut and washer.
4. Remove stabilizer shaft or link from control arm.
5. Remove nut from ball joint, then separate ball joint from steering knuckle using separator tool No. J-36226, or equivalent.
6. Remove drive axle from hub and bearing assembly using front hub spindle remover tool No. J-28733-A, or equivalent, Fig. 8 .
7. Remove drive axle from transaxle using axle shaft remover puller tool Nos. J-33008, J-29794 and slide hammer tool No. J-2619-01, or equivalents, if necessary, Fig. 9 .
INSTALLATION
1. Install drive axle into the transaxle using seal protector J-37292-B, or equivalent
2. Seat snap ring by placing a screwdriver into the groove on the joint housing and tapping until seated, Fig. 9 .
3. Grasp the inner housing and pull outward. If the snap ring is properly seated, the axle will remain in place.
4. Install drive axle into hub and bearing assembly.
5. Install lower ball joint to steering knuckle and tighten to specifications.
6. Install stabilizer shaft or link to control arm, tighten to specifications.
7. Insert a screwdriver or drift into caliper and rotor to prevent rotor from turning, Fig. 7 .
8. Install new hub nut and washer, tighten to specification.
9. Install tire and wheel assembly, then lower vehicle.
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Jul 20, 2024 at 6:09 AM
