1996 Cadillac El Dorado Message on message system
1996 CADILLAC ELDORADO
134,000 MILES • V8 • 2WD • AUTOMATIC
FATFORD40
I am getting a message on my message center in regards to checking ride control. I know this has to do with the suspension. Recently I had two people in the back seat and the car automatically bottoms out. Can you tell me what this message refers to and what the fix might be? I also would like to find a repair manual for this vehicle as well.
Oct 19, 2008 at 8:57 AM
JNOVACK
  • 723 POSTS
there should be a switch in the trunk on passenger side turn switch off then on and check the fuse in fuse box under dash driver side check for blown fuse may I ask if you had work done on car that required the car to be lifted repair manuals may be purchesed from link at bottm of my post
Oct 19, 2008 at 9:13 AM
FATFORD40
I am the new owner and I personally have not had it lifted, but don't know about previous owner. I will check on the switch. This message comes on from time to time when I drive the car. The car seems a
little "bouncy"/not dramatically, when I go through dips or hit a bump.
Oct 19, 2008 at 9:19 AM
